02-16-02, 08:18 AM
tjdjwanek
How to change a serpintine belt on a '99 suburban?
02-16-02, 10:20 AM
mooser1
if you don't have a service manual, check www.autolibrary.org
it gives details with drawings of your belt change proceedure....
what it amounts to is taking a breaker bar with a socket that will fit the hex on the front of the spring loaded tensioner pulley, pushing against the spring to relieve the tension and allow the old belt to come off.....
replace new belt in reverse fashion, there's a diagram of the belt routing on top of your radiator or fan shroud if you get confused...
happy wrenching
happy wrenching
02-16-02, 07:30 PM
Joe_F
The engine size of the unit helps for one..
Mooser put you on the right track.
