92 crown vic blows fuel fuse with key on.
Old 02-17-02, 04:35 AM
L
lcpiii27
i changed the fuel pump sence the car had 100000 miles on it. the fuel fuse blows out when the key is turn to the on position.
i have bought a sending unit. i attached it to the pig tail. there is voltage,but the pump will not run. i have tested the sending unit and fuel pump outside the fuel tank. the voltage drops once i connect the blk. wire to the pump. i will back trace the harness to the engine compartment to find the short. thank you for getting me back on track.
Old 02-17-02, 07:49 AM
Joe_F
May have pinched a wire on the sending unit from the fuel pump repair.
