Ford Trans
Thunderchicken's Avatar
02-17-02, 07:26 AM   #1
Thunderchicken
Ford Trans
I found the linkage from the transmission to throttle body disconnected. I replaced clip and reconnected linkage to throttle body, but it still does not go into overdrive. Any suggestions?
Joe_F's Avatar
02-17-02, 07:45 AM   #2
Joe_F
Type of vehicle? Type of transmission? What does your service manual say (check the links below if you don't have one).
Sounds like the linkage is off.
02-17-02, 07:57 AM   #3
Thunderchicken
Ford Trans again
The car is a 1992 Ford Crown Vic with a 5.0 . All I know about the trans is that it is an automatic w/overdrive. It stopped going into overdrive on my way home one day and I had to put it in drive to even move. I drove it up the road after replacing the clip and that's all. I'm afraid to drive it because I don't want to ruin it if it can be fixed. Can that linkage come loose somewhere else?
Joe_F's Avatar
02-17-02, 08:04 AM   #4
Joe_F
Again, hit the links I have provided and they should have the linkage adjustment procedure.
Start there and tell us what you get.
fordtech's Avatar
02-17-02, 02:56 PM   #5
The linkage you mention is adjustable.There is usually another clip on the linkage itself that you remove to adjust it.I'd recommend a shop check it though for the proper adjustment due to if it's not right it can cause transmission failure.
02-20-02, 02:05 PM   #6
Thunderchicken
I checked to make sure it was connected on the transmission and it was. I could see the shaft going into the transmission turned when I moved the linkage. I haven't dropped the pan because I'm not sure if there is anything I can do after I do. What next?
Joe_F's Avatar
02-20-02, 09:45 PM   #7
Joe_F
Do as Fordtech suggested and have a good shop or tranny shop set it up for you.
It is similar to the TV cable on a 700R4 GM. If it's not right, you will wipe out the trans. in a jiffy.
