timing connector
Old 02-18-02, 12:01 PM
Berch
timing connector
Hi, on a 95 GMC surburban, where is the timing connector located. Need to check the timing.
thanks.
Old 02-18-02, 12:28 PM
mooser1
which engine do you have in the truck?
Old 02-18-02, 12:42 PM
Joe_F
As I stated in the other post, there is no need to check the timing. If you suspect timing issues, the chain is likely stretched.
Modern vehicles do not require timing adjustments. The computer compensates. Only when the chain breaks or wears out would you need to set base timing in most typical cases.
You will gain zero benefit by bumping up the timing on a stock fuel injected vehicle.
