ball joint 1995 blazer 4x4
Old 02-21-02, 07:28 PM
droopy1961
I'm changing ball joints on a 1995 blazer midsize 4x4, I have the ball joint loose, but I can't get it to clear between the drive axle and the lower swing arm. Question is do I have to pull the drive axle? I'm going to change the top ball joint too, but that still won't help the clearance. I did already remove the grease fitting out of the top of the ball joint , but still not enough room to get it out. Thanks , Droopy1961
Old 02-21-02, 07:52 PM
mooser1
according to Hayne's service manual, yes, the drive axle must be removed to replace lower ball joint....
