92 Chevy S-10
Old 02-23-02, 07:00 AM
wingplow
92 Chevy S-10
I have a 92 S-10 with a 2.8 v6. The oil pressure gage shows o pressure when running. There is no noise from the motor at all.
It runs good and strong no other problems at all.
Do you think it could be a bad oil sending unit and if so where is it located.
Thanks
Old 02-23-02, 08:33 AM
mooser1
the sensor should be located just behind the distributor and to your right as you look at the engine......
Old 02-23-02, 10:18 AM
Joe_F
Yep, likely a bad sending unit. Common problem. Any parts store has this part...only a couple of bucks.
Old 02-23-02, 09:53 PM
0patience
The oil pressure sending unit is located on the oil filter housing.
NOT by the distributer. They run around $30.
Check that the connector hasn't come loose from the sending unit.
