blinker
Old 02-25-02, 03:47 PM
D
blinker
I have a '96 Aerostar. The right blinker works when I hold it (as one would when changing lanes on the interstate), but it does not work when I turn in on all the way (till it clicks and stays on until the vehicle turns). Any ideas about what needs fixed?
Old 02-25-02, 07:33 PM
F
It sounds like your problem is in your multifunction switch(turn signal switch).It's easy to replace.Just take the steering column shroud off(3 or 4 phillips screws),remove tilt lever(If it has it just unscrew it to the left),2 torx(star)bits hold the switch to the column.Unplug the switch,and reinstall in the reverse order.
Old 02-26-02, 01:28 PM
D
Thanks a lot! I'll try that! Sounds easy enough.
Old 02-26-02, 05:20 PM
F
Your welcome and good luck
