spider gear removal
jz brake's Avatar
03-02-02, 04:13 PM   #1
jz brake
spider gear removal
84 chevy 4 by 4 1/2 ton pickup, 208-c transfer case, 700 r 4 trans, 305 motor and a 3.07 12 bolt posi-trac. rear end. the differential is not a "limited slip" differential. my question is where can i purchase the tools to remove the roll pin and the locking components, "wich are press in" so i can remove the spider gears for inspection and cleaning. iwould like the part number and the brand for the tools.
toiletjockey's Avatar
03-02-02, 05:05 PM   #2
toiletjockey
Try contacting Rieder Racing.com. This there cup of tea so to speak. If they don't have the tools they probably can tell you where.
Joe_F's Avatar
03-03-02, 06:10 AM   #3
Joe_F
Get the GM service manual before you go any further .
It will have the complete R&R procedure of the rear axle.
Kent Moore Borroughs for one company supplies GM dealers with their tools. Other companies (Lisle, Craftsman, Snap On, KD, etc) make their versions in some cases.
jz brake's Avatar
03-03-02, 06:34 AM   #4
jz brake
i figured you will mention a gm service manual. i forgot the library. thanks for reminding me.
Joe_F's Avatar
03-03-02, 03:41 PM   #5
Joe_F
My rule of thumb:
If it's not worth spending the dough for a GM book, it belongs on the back of a hook to the heap yard .
The detail in those manuals will blow you away .
