tires?
cschroth1's Avatar
MA
03-02-02, 07:55 PM   #1
tires?
Hi,
I have a 1991 Ford F150 4x4 exteded cab with the 5.0L motor.
It currently has 159,000 miles on it,but is in good mechanical cond.
I plan to keep it till it dies!
I need some info on tire replacement.I use 235/75R15LT,I find the "LT" tires have a stiffer sidewall,at about 50psi.As I tow a 29ft travel trailer,they seem to handle better.
What brands do you recomend?I do 98% "highway" driving.
I also need a good All Season tire for the NewEngland weather.
Any recomendations?Thanks, Charlie
Joe_F's Avatar
03-03-02, 05:55 AM   #2
Joe_F
Might want to pick up an extra set of rims for it and swap on Blizzaks or other radial type snows for the winter.
Any tire that is a good combination of Traction (A, B,C, A being the best) Temperature (same grades as traction) and Treadwear (the higher the # the better) is the tire to go with.
As for tire pressure, contact the tire maker of whatever brand you buy for recommendations.
