Heater turns cold and can't use key to unlock driver's door
Iam K.C.'s Avatar
03-04-02, 12:26 PM   #1
Iam K.C.
I have a 1989 Buick Century with automatic door locks. After trying to use a random key to try to unlock the drivers door (keys locked inside), now I cannot unlock the drivers door with the correct key. Can it be fixed? Also, if I keep sliding the Heat/Cold switch back and forth, I can finally get the air to turn hot from cold, but then after a few minutes it will turn cold again. Whats wrong?
Joe_F's Avatar
03-04-02, 02:08 PM   #2
Joe_F
Putting the wrong key in the lock likely jammed the tumblers and ruined it. Get a new lock from a locksmith keyed to the original.
As for the other issue, sounds like a problem with the blend door/cable. Have to take it apart and have a look to see if the cable is hung up or weak/frayed.
