Ford Probe exhaust
Old 03-06-02, 06:44 AM
Ford Probe exhaust
I have a 1991 Ford Probe with a 3.0 liter engine. The flexible, braided portion of the exhaust (directly behind the catalytic converter) needs to be replaced. Any tips on doing this? I do most of my own car maintenance, but normally don't work on exhaust systems. However, this looks like something I might be able to handle. Any thoughts, tips, tricks?
Old 03-06-02, 07:20 AM
Joe_F
Unless you have a torch or an air compressor, leave it to a shop.
The bolts will rot in place and be a bear to remove. If the studs go into the manifold, they will be a PITA to change and will probably snap from rust and age.
Old 03-06-02, 11:02 AM
xiii13
I agree wirh Joe. If you break the studs that go into the manifold it's a PITA to repair. Let a muffler shop do it. This type of repair is not worth the aggravation.
Old 03-08-02, 07:25 PM
hp246
I agree with both of the above. Also, if you do a little research, they should be able to adapt some parts to make the repair, rather than seel you the 1 piece exhaust system that is the listed part.
