Heater does not heat up
Old 03-06-02, 05:54 PM
Dale Cushwa
Question Heater does not heat up
The heater in my Olds cutlass ciera does not get hot, how do you change the thermostat?
Old 03-06-02, 07:54 PM
Joe_F
The year and engine size of this A body winner helps.....
Might not be the thermostat. Warm up the car. Feel the heater hoses going to the firewall. If they are both hot, the problem is the blend door inside the car, not the stat.
Barring that, get a repair manual for your car from the parts store or library to guide you through replacing the stat. The links in my signature file might help with some info.
