f150 ignition
Old 03-07-02, 09:24 AM
goran
Question f150 ignition
I'm unable to insert my key into the ignition all the way so that I can start the engine. It worked fine an hour before, but now the key just won't go all the way. Whats the problem??
Old 03-07-02, 09:42 AM
Joe_F
Bent key, problem in the lock. Try lubing the key and lock with WD40 or graphite.
Make sure the lock is fully in the LOCK position or the tumblers won't line up.
The lock cyinder and/or key is also likely worn out too.
