1989 Pontiac Bonneville
Old 03-08-02, 11:31 AM
MickB
the damned thing won't start! turns over but wont start. Did start once, but died right away. Think fuel filter would be it? Any ideas?
Old 03-08-02, 12:37 PM
Joe_F
Check my post "The Basics" and the links show below in my signature file.
Old 03-10-02, 02:24 PM
MickB
I've replaced the spark plugs, battery and fuel filter. It has started once more, but immediately dies again. Any other suggestions?
Old 03-10-02, 02:57 PM
Lightbulb
You might want to check your fuses if it has burned. Good luck on the repairs. Keep me posted.
OM
Old 03-10-02, 03:43 PM
MickB
Thanks. Checked fuses, all look good. Any other suggestions?
Old 03-10-02, 06:11 PM
Lightbulb
I would suggest to check for fuel & spark. Good luck on the repairs. Keep us posted.
OM
Old 03-11-02, 08:42 AM
Joe_F
Possible mass air flow sensor. Tap on it while it is running or off and see if it now starts/hesitates.
Again, must start with the Basics (Hint). As OM said, have to know whether you are lacking fuel/and/or spark.
Without that, we cannot go any further.
Old 03-11-02, 06:14 PM
rickwhoo
sounds like the crankshaft sensor
