Map sensor
Alibaba_z's Avatar
03-09-02, 11:39 AM   #1
Map sensor
Recently, I asked the location of my map sensor on my 1993 Plymouth Grand Voyager Van. I Failed to list the engine size. It is a 6 Cyl. 3.0 engine. I thank you in advance for your help. Needless to say that in the past your advice was always on the money. Again thanks.
Joe_F's Avatar
03-09-02, 11:59 AM   #2
Joe_F
Look under your hood. You will see an emission diagram. It will show you where everything is. Most Chryslers typically have them on the firewall bolted to a bracket.
Hit your parts store or Chrysler dealer for a new sensor. Some years have a revised sensor and bleed package as Chrysler had a problem with some years with moisture getting into the line.
Gix's Avatar
03-09-02, 02:56 PM   #3
Gix
im thinking right in front of the manifold somewhere close to the alternator on a bracket
