Ford Pickup Truck. Clutch Switch
Old 03-10-02, 12:45 PM
TomBranson
Question Ford Pickup Truck. Clutch Switch
How do I contact a wire around the clutch switch to see if its working? What kind of materials do I need?
Old 03-10-02, 12:55 PM
the_tow_guy's Avatar
If we're talking about the safety switch, locate the switch, pull the connector off and jumper with a small piece of wire between the two terminals in the plug. Should be able to crank engine. Best way to check the actual switch would be with a continuity tester (ohmeter). With harness plug disconnected as above put meter leads on the 2 switch terminals. With clutch engaged (pedal "up") you should read no continuity across terminals (open circuit). When you depress clutch and switch closes you should get continuity across terminals (closed circuit).
Hope this helps.
Old 03-11-02, 08:49 AM
Joe_F
Thumbs up
I agree..but...
making also sure that the vehicle is in neutral or it will lurch forward!
Other than that, TowGuy gave you some solid advice.
Old 03-11-02, 06:39 PM
Right, Joe. Personally I've never needed that safety switch because when I learned to drive a stick back in the stone ages the first thing I learned was that the very first step in starting was to push clutch pedal to floorboard.
