Turn signal/Hazard lights?
Old 03-10-02, 05:11 PM
Unhappy Turn signal/Hazard lights?
Hi,
I own a 1995 Lincoln TownCar,with the 4.6L motor.
Today I noticed the Blinkers,as well as the Hazard flashers
aren't working?
The turn signals light up on the front,but don't flash outside,or on the dash?
Also the Hazard flashers don't work?Any ideas???
I couldn't locate the flasher unit either,where is it,and could that cause this?Thanks, Charlie
Old 03-10-02, 05:51 PM
Lightbulb
Hold on dont just change the flashers. Check the turn lamps first if they are stil good. Good luck on the repairs. keep us posted.
OM
Old 03-11-02, 08:44 AM
Joe_F
If both the hazards and the signals are not working, and all fuses/breakers check out, likely a bad multifunction switch in the steering column.
