Bulb replacement??
Old 03-11-02, 04:39 PM
C
Unhappy Bulb replacement??
Hi,
I own a 95 Lincoln TownCar,and both the Hazard lights,as well as the blinkers don't work at all?
The front "Cornering Lights" do light up when the blinker is put on,but the rear does nothing.The rear bulbs seem to all be working.
I can't figure out how to get at the front amber turn signal bulbs to check them?Theres only 1 screw visible on the side?
Is anybody familar with removing these?
I wote yesterday,and got a reply that it's probably the buls,and not the flasher unit?Any ideas?Thanks, Charlie
Old 03-11-02, 07:50 PM
Joe_F
Keep all your posts on one vehicle together for clarity and so everyone can follow. Use your reply button.
That being said, sounds like as I mentioned yesterday a bad multifunction/turn signal switch in the column.
Old 03-16-02, 03:36 AM
C
Red face Found problem,
Joe,
I got the car checked out at a shop,you were right.It was the Multi Function switch.Thanks again, Charlie
