92 explorer 4 wheel drive
joe kyle's Avatar
03-14-02, 12:33 PM   #1
joe kyle
the 4 wheel drive will not engauge
the light comes on but it dosent do anything
i just replaced the wheelberings ,also the brakes and rotors
Joe_F's Avatar
03-14-02, 12:41 PM   #2
Joe_F
Probably a stuck solenoid or glazed brushes inside. Or, if vacuum operated, a bad switch.
Check the archives here for a link furnished by Knuckles on how to rejuvinate the solenoid if so equipped.
Look up "glazed brushes" for instance in the search function of this forum. Knuckles posted a link on how to inspect and restore the solenoid. The problem is likely here and is worse if the 4WD is sparingly used.
chadtoolio's Avatar
03-14-02, 05:01 PM   #3
chadtoolio
Did the problem start after you replaced all those parts? Do the hubs automatically lock or do you have to engage them yourself?
joe kyle's Avatar
03-14-02, 05:38 PM   #4
joe kyle
92 ford explorer
the prob happend after i put the parts in
it has auto hubs
chadtoolio's Avatar
03-14-02, 05:42 PM   #5
chadtoolio
Sound like you goofed on the reinstallation on the locking hubs. Get a diagram of the parts in a manual and dissasemble and you will probably see your problem. The locking hub has to be phased right.. been a long time since i did one but I believe I goofed on one before.
Good luck, Mistakes can be the best experience
joe kyle's Avatar
03-14-02, 05:47 PM   #6
joe kyle
thanks chad i think that is going to help me out
