automotive
Old 03-14-02, 09:31 PM
sts
automotive
How to oil or loosen window handle - cannot open window.
Old 03-15-02, 12:05 AM
K
knuckles
Year/Make/Model ????
Manual or Power windows???
We can't provide accurate info if you don't provide us with basic info.
Old 03-15-02, 05:21 AM
Joe_F
Assuming its a crank window.
Pop off the panel and have a look inside. Check the links in my signature file for some ideas.
Old 03-15-02, 08:18 AM
It's not as simple as oiling the crank......Most likely their is something binding in the regulator system......Joe is correct that you need to take the door panel off and inspect for a bent/broken or misaligned assembly.........
You say you cannot open window.........If you can open it however it's tough, you might firsrt try spraying the front and rear glass channels with a silicone spray........
