96 Toyota Tacoma
Old 03-16-02, 11:26 AM
Marill
96 Toyota Tacoma
my emergency brake light won't go off when I release the brake, can't figure out why?
Old 03-16-02, 11:35 AM
the_tow_guy's Avatar
Received 45 Votes on 36 Posts
Don't recall the parking brake setup on a Tacoma, but there'll be a switch somewhere near the handle/lever. May just be sticking from dirt and crud or may need replacement.
Old 03-16-02, 11:39 AM
C
chadtoolio
Is it an emergency brake light warning or a combination emerg. brake and brake fluid level/pressure light. Have seen this in many vehicles..
If combination, check the brake fluid level. A low fluid level can indicate that there is a leak in the system or that it is time for brake work.
If just an emerg. brake light, should be a simple switch that turns on off the light. Check the switch with an ohm meter to see if it is working properly. It should supply a ground to the Instrument cluster to turn the light on.
Good luck
Old 03-16-02, 03:34 PM
Joe_F
I agree. Check the brake fluid level. Probably low due to worn pads/shoes or a hydraulic issue. Fix it right away.
