Alternator problem update, still ???
Old 03-17-02, 11:50 AM
kb9nqd
Since my last post I have had 2 automotive stores check my charging system and both state it is good and well within normal parameters as far as charging voltage/amperage. Guage is reading normal however the battery idiot light is still on. Any guesses as to why it would stay on? 92 Ford Aerostar 3.0L w/air. The battery is less than 3wks old. Thanks
Old 03-17-02, 04:50 PM
Joe_F
Could be a stuck diode in the alternator or you have a wire loose or missing/burned through setting the light on.
Try doing the output test for your charging system listed in my post "The Basics" below and tell us what you've got with that.
Old 03-17-02, 05:14 PM
cheese's Avatar
I agree...I've had alternators tested at parts places, and they say it's good, but their machine didn't pick up on the fact that there was a bad diode. More than once I bought an alternator on faith in my diagnosis, not their machine. I was right, and this may be the case in your situation, or you could also have a short in the wiring to the light like Joe mentioned.
