89 Sable Water Pump
Old 03-17-02, 02:53 PM
toddy355
Question 89 Sable Water Pump
What is all involved with replacing the water pump on an 89 Merc. Sable other the removel of alternater and the AC compressor. I am wondering no how big a job that it is?
Old 03-17-02, 04:48 PM
Joe_F
The engine size would help...
Check the links in my signature file for some service manual information which will give you some idea.
It's a bit extensive because of the packed in nature of everything around it that has to come out.
Old 03-17-02, 05:39 PM
the_tow_guy's Avatar
If it's a 3.8L and you're replacing it for a leak, make sure you're positive it's the water pump leaking (I'm assuming same engine/layout as that '93 of my brothers I had to do, Joe?)
If it's the same motor, check this thread:
http://forum.doityourself.com/showth...threadid=77375
And on my job the ac compressor wasn't in the way (but on an '89 it may sit in a different location.
Old 03-17-02, 05:58 PM
toddy355
Hi sorry the motor is a 3.0 and not sure about exact location of leak but it is all wet under the pump and when running the water pump pulley is not spinning true a slit wobble which leads me to believe a bearing is out.
Old 03-18-02, 03:32 AM
Joe_F
Sounds like a wiped water pump for starters. Make sure everything else is true when you do the job.
