82 Subaru GL
Old 03-18-02, 09:30 AM
B
bookworm686
Question 82 Subaru GL
82 Subaru 1600 GL hatchback189k miles all of a sudden all the indicator lites door open etc etc on the telltale gauge came on while driving and car died similar to running out of gas. it will start for a second then die. appears to be fuel pumping out of fuel pump but ind. lites still are on any ideas???
Old 03-18-02, 10:05 AM
X
xiii13
Had a similar problem on a '88 Suburu. Turned out to be a bad alternator. Have it checked out.
Old 03-18-02, 10:59 AM
Joe_F
I agree. Likely a bad alternator causing things to go haywire.
Check my post "The Basics" for how to do a charging system check. See what the output is and then you'll know if the alternator is gone or not.
Old 03-18-02, 04:01 PM
C
chadtoolio
Don't think I would go out and buy an alternator just yet.
Is there any fuel in the carburetor bowl? Can you pump the throttle and see it spray?
Can you keep the car running with carb spray?
