Suzuki dies as if out of gas
98Swift's Avatar
03-18-02, 12:53 PM   #1
98Swift
My wifes 97 Suzuki Swift (1.3L) will run for about a minute after start up, will then start to shudder and stutter progressively worse till it conks out. This just began 2 nights ago after she filled up at the local convenience store/gas station. Let it sit about an hour and the same thing will occur, its good for about a mile. All my armchair mechanic friends say fuel filter or injectors. I'm clueless, but could probably handle checking the filter if I knew where to find it......Any help out here
Joe_F's Avatar
03-18-02, 01:11 PM   #2
Joe_F
Start with the fuel filter, as you likely picked up junk from the station.
Follow your lines from the fuel tank and look for a thing shaped like a can. That is the fuel filter. Typically under the car, but on some might be bolted to the firewall.
A quick call to any Suzuki dealer should net the location in a jiffy. Pick up a repair manual to guide you through any repairs.
