Fuel Pump 95 Ford Aspire
Old 03-18-02, 03:29 PM
BIGWILLY1201
Unhappy Fuel Pump 95 Ford Aspire
I have a 95 Ford Aspire and this *#@$* is givin me a head ache. I have checked the fuel filter and the ignition wires. I am convinced that my fuel pump has gone out. Any instructions on how to fix it would be greatly appreciated.
Old 03-18-02, 03:38 PM
chadtoolio
You need three things to make a car run:compression, ignition, fuel
It should be very easy to diagnose seeing how it doesn't start at all
Is the motor in good mechanical shape?
Do you have spark?
Do you have fuel pressure/injector pulse?
Good luck
If you don't have spark you won't have fuel!
Old 03-18-02, 05:07 PM
BIGWILLY1201
reply to chad
Well I have spark, half tank on fuel. I think I have found the that the filter is good, but when i took the filter off there was no fuel coming from the bottom line that goes to the tank, so I think it is the fuel pump. Thanks. It looks like a job for a pro.
Old 03-19-02, 06:12 AM
Joe_F
Start with the links and posts in my signature file and let us know what you find.
