engine fan removal
engine fan removal
need to remove engine fan, its a 5.7 and the fan isnt a typical fan. It has a long hex nut on shaft between fan clutch and belt pulley. Removal of the four bolts on the pulley to water pump flange doesnt remove the fan.
Because I believe you need a special tool to remove the fan/clutch
Check out Lisle Tools website. I know they for one company make fan clutch wrenches.
You might also try Autozone through their tool rental program.
Previous Thread
Next Thread
