for some reason, when I put the car in reverse the car makes this funny ticking noise....any ideas on what it may be??
Also, I just bought another car...an 88 Tracer.....I bought the car from a car lot...the lady's friend used to own the car...he lost the ignition key, so the whole ignition needed to be replaced. It was replaced by a mazda ignition...when the car is idling in park, it runs just fine..you stick it in drive and the car acts like it's going to stall on you and it sometimes does stall on me...when you try to start going, the car acts like it's a manual and the clutch isn't wanting to let go or something...it lurkes forwards when it finally starts going somewhere...what are your ideas on what is causing this problem, or can you not tell by the way I'm explaining it...I'm not sure exactly how to explain it......
babygirl
im in search of someone knowing how to disable the door chyme/key buzzer on a 2000 toyota 4runner the problem is that you cant have the door open in the accessory position without that stupid chyme ringing i want to disable it but am unsure how to go about it
sincer thanks to any helpful sugestions you might have
