starts if used often
Old 03-25-02, 09:19 PM
artie
81 dodge ram 350 3/4 ton van; 318 motor, auto, 4bbl.
it wont start without priming if left parked for 3 days or longer, is it the fuel pump or the float bowl cracked?
Old 03-26-02, 05:13 AM
Joe_F
Likely a bad fuel pump. Chrysler carburetion is the rock bottom pits .
Check your fuel pump output with a gauge. Barring that, probably time for a carburetor rebuild.
Old 03-29-02, 12:40 AM
knuckles
1. Please keep all replies in the same thread.
2. Fuel pump pressure can be checked with a fuel pump pressure/vacuum gauge. You can pick one up at your local auto parts store for $10 or less, or you can use any gauge with a scale of 0-10 psi.
3. Please read Joe_F's signature file. It contains links to sites that will provide you with the information and specifications you need.
Old 03-29-02, 05:40 AM
Joe_F
I agree.
You can also rent the gauge at any retail parts store with a tool rental program.
Check my signature file for more ideas.
I will close the other post as it is a duplicate.
Old 03-29-02, 08:58 PM
trendar
In addition to the pressure check while running, you can also see if the pressure drops over time when it sits while off; may be a problem with the pump allowing the fuel to drain back, since you say it happens only when sitting for a while without starting, but otherwise works okay if started often enough.
Old 03-30-02, 06:58 AM
artie
these are interestingtips and I will use them as soon as my 25th wedding anniversary party is over, on momday april 1st, thanks.
Old 03-30-02, 07:00 AM
Joe_F
Thumbs up
Good luck and happy Anniversary
