Help !!
Old 03-26-02, 09:19 AM
corsi
Help !!
Hello, all, I'm new here and this board is great.
I have a 93 3.1L Corsica.
The problem is that the fan works when the engine gets too warm but does not come on when the a/c is on.
It's a problem because the engine overheats.
What's going on?
Thanks guys.
Old 03-26-02, 09:33 AM
Joe_F
You might have a bad fan control switch or you have fault in whatever turns the fan on when the A/C is cycled.
Check the fan circuit using a wiring diagram. I would start with the radiator fan or temperature switch turning on the fan.
Check the links/posts in my signature file for some ideas.
Old 03-26-02, 12:46 PM
xiii13
There's a separate A/C relay for the fan. Replace it. Costs about $20.
