I replaced the coil in the distributor, which caused no start in 1990 Honda Accord. The multimeter reading will show everything is OK. But it was indeed COIL at fault.
Good Afternoon all,
Quick question. I have a 01 dodge stratus, and today i pulled into a parking spot, it caught my bumper, and while reversing out, it pulled partially off. Well i put it back on, but noticed that by having it torn, it tore all the holes that the screws went into on the bumper itself. It is holding good, as far as i can tell, but i am curious how, or what i can use to reinforce the bumber so it doesn't slide off again. I hope this makes sense. I was thinking if they made a washer with one side that had teeth of some kind so when i screw it in the teeth will dig in aroung the ripped hole and it would better stabalize it, but i don't know if something like that exists. Please any help on this will be greatly appreciated.Read More
Truck has two fuel pumps one in each tank, the forward unit stoped working. I replaced the pump and switch, yesterday, ran good for about 60 miles, stoped truck and went to start about 3 hours later and fuel pump would not work.
How can I get a wire digram for the fuel pump systemRead More
