Car Problem
Old 03-29-02, 05:17 PM
ETLBAY
Car Problem
I HAVE A 1993 CROWN VIC, V8. 5.0. MY PROBLEM IS THAT MY CAR SMOKES AND IS BURNING OIL, THE CAR RUNS GOOD OTHER WISE
Old 03-29-02, 06:08 PM
knuckles
The problem is most likely worn valve stem seals. It's a very common problem on the early 4.6L engines.
You can replace the seals yourself if you're an above average DIY mechanic. Otherwise, see your local auto repair shop.
Old 03-29-02, 06:16 PM
ETLBAY
Thumbs up THANKS
THANKS YOU
E.T
Old 03-29-02, 06:25 PM
knuckles
Question
I just re-read your original post....You say you have a 5.0L engine...hmmm...
I know *some* 1991-up Crown Vics used the 5.8L, but these were police cars & taxi cabs.
What color are the valve covers & does the engine have a distributor?
The 4.6L valve covers are black plastic & there is no distributor.
The 5.0L & 5.8L have either gray steel valve covers or bare aluminum valve covers & the distributor is located in the front of the engine.
Old 03-30-02, 06:58 AM
Joe_F
The 1991 vin code G 5.8 engine is carbureted with a pesky Variable Venturi 2 barrel and stops being used in 1991. It is a police/fleet issue only engine.
The last year for the 5.0 in a Town Car is 1991 I believe.
You'll easily know by looking at the Vin # on the dash. If the 8th digit is a W, you have a 4.6.
By the sounds of your problem, you SURELY have a 4.6. Notorious puffers, very poor with oil control.
Knuckles gave you some good advice as well.
Trackbacks are On
Pingbacks are On
Refbacks are On
