Timeing belt
Old 03-30-02, 09:16 AM
butchtropic
Timeing belt
Hello I have a '94 escort, 1.9 litre engine. I was replacing a leaky
water pump and when putting the timeing belt on it slipped off
the idler. I know how to alighn the marks on this engine as I replaced the belt 20K ago. The problem is the crank moved maybe
a full turn or two before I realized what happened. Can I just
re-alighn the marks as usual or do I have to find TDC and try to go
from there?? any help would be grately app....
Old 03-30-02, 12:03 PM
chadtoolio
I could be wrong, but I don't believe that the 1.9 in that car is a valve bender so putting the crank back at tdc and reinstalling the belt while aligning the marks shouldn't be a problem.
Good luck....
Old 03-30-02, 04:11 PM
Joe_F
Check the links in my signature file for some ideas.
Old 03-30-02, 10:57 PM
butchtropic
Thanks for the info Chad, I found TDC on #1 cyl. and re-installed
the belt. Running fine now,-phew- feel like I dodged a bullet on
this one! I've had this car since new and always changed the oil
and taken good care of it, would have been a bummer to crush
my valves! Again, thanks......
