Engine Locked?
Old 03-30-02, 08:14 PM
DIZSTURBEDX2
Engine Locked?
Hellllllppp...My wife has a 96 Chevy Lumina....100,000 miles...had been running hot, but no heater working..had thermostat replaced..seemed fine...
Today, highway driving, started to overheat...By the time I was able to get off the highway, temp gauge pegged out...Stopped for a light, and the engine died...Popped the hood, coolant recovery tank full, but the radiator was not hot...Able to pop the radiator cap w/out having to wait...Looks like water pump was leaking...Added coolant, but now it won't turn over?? Is the engine seized up or possibly something else?
Old 03-30-02, 08:44 PM
marturo's Avatar
Check rotation
This sounds bad. Take out all your spark plugs, and with the starter try and crank it over. Make sure you have a good charged battery.
Write back after you check.
Marturo
