Hydrolic Problem, Windshield Hose
Old 03-31-02, 06:44 PM
joeybergeron
Question Hydrolic Problem, Windshield Hose
Hello, I have two problems with my 95 Nissan Pathfinder. 1.) I have two little hydrolic cylinders that help retain my back hatch door in the raised position. How do I fix these hydrolic cylinders to keep my back hatch door from coming down? Also, 2.) My windshied hoses are apparently clogged because they do not pump in fluid, any tips on the best way to unclog them?
Old 03-31-02, 11:08 PM
knuckles
1. The lift cylinders are not serviceable. Replace them with new units.
2. Disconnect the hoses from the washer nozzles and activate the washer pump.
If washer fluid pumps from the hoses, clean the washer nozzles.
If fluid does not pump from the hoses, suspect a washer pump or switch problem.
Old 04-01-02, 05:24 AM
joeybergeron
Thanks, I appreciate all the help!
