1996 Corsica 3.1 V-6 Intermittent problem starting. Can Hear Whirring, clicking
Old 04-01-02, 02:23 PM
drew47
Please help!
My Corsica will not start sometimes. Engine turns. I hear whirring clicking only when car isn't going to start. Usually after a few tries it starts andf runs fine. I'm sure it will quit completely sometime.
Old 04-01-02, 04:08 PM
Joe_F
Need a better description on the problem. From this, sounds like a wiped starter or poor connection.
Old 04-01-02, 08:27 PM
drew47
The starter turns the engine just fine. The whirring clicking sound is like it is behind the glove box. I suspect a fuel injector relay but I don't want to just start replacing unless this will fix my problem.
Old 04-02-02, 07:01 AM
Joe_F
Could be a bad blower fan motor. Disconnect it and see if the whirring goes away. If it does, look for a bad fan motor/restrictions in the blades.
Old 01-31-08, 10:59 AM
C
when the car doesnt want to start get under the hood pull one of the plugs stick the plug back into the plug wire, have someone crank the motor and see what color the spark, if it isnt blue your ignition module is going out...
Old 01-31-08, 03:49 PM
Received 30 Upvotes on 29 Posts
Where did you pick up all these ancient threads? Your computer must be stuck in a time warp. But, hey, it's still good information!!
