Power windows
Old 04-02-02, 10:35 AM
gr8tune
Power windows
I'm trying to remove the power window assembly on a 1996 pontiac sunfire. I removed the door cover and plastic covering, and drilled out the rivets that hold the assembly in place. What's next?...I can see the door track and the bars that attach to it, but don't know how to remove it. Please help!.
Old 04-02-02, 11:14 AM
Joe_F
Whoa Nelley. What does your service manual say?
Check the links in my signature file for some ideas. Shouldn't tear into it without reading it first .
The door glass likely has to be separated from the regulator and removed and then the regulator. Why are you in there now?
Old 04-02-02, 01:19 PM
darrell McCoy
Listen to what Joe Sez. Read a manual. These are tricky and you need to follow correct procedures, else you can end up with an "ouchie" plus other unwanted headaches.
