water pump belt 88 jetta carat
Old 04-03-02, 10:17 AM
timmy_pman
Angry water pump belt 88 jetta carat
I am trying to replace all the belts in my 88 jetta 1.8 and I cannot get the damn lower belt off (Water pump) . I don't know if it is all seized up or if the I trying to do it wrong but I can;t find a repair manuel online that's free and now I don't have a car to go buy one. Is anybody familiar with this procedure? Is there a trick? Thanks in advance.
Old 04-03-02, 10:21 AM
Joe_F
Check the links in my signature file for starters. You might also consider an alldata.com subscription which gives you factory type information as well.
Make sure you are loosening the proper bolts. If you are, it's probably seized
Old 04-03-02, 05:48 PM
system
system
It is a bit of tricky to remove the lower belt, look closely I believe you haven't loose one of the bolt that why u can't take off the belt.
