starting problems
Old 04-03-02, 09:50 AM
billablunt
starting problems
I have a 1995 z28 camero and just the other day it would not start and continues to not. At first the engine would turn over and not catch, but after I sprayed some starting fluid into the air intake the engine would fire up and run for about 5 seconds and then kill. I am wondering if there is a way that I can fix this or am I going to have to call a tow truck?
Old 04-03-02, 10:27 AM
Joe_F
Start by checking my post "The Basics"
If stoking it with fuel/carb cleaner like that makes it stay running, you like have a fuel problem. Perhaps a bad fuel pump.
Old 04-03-02, 10:48 PM
system
I have remove the fuel tank on this this model, all I can say is stupid designed, u have to remover the exhaust, the spring, shock lower the differential a bit...... good luck.
Trackbacks are On
Pingbacks are On
Refbacks are On
