ford explorer hood riser
how to remove and replace the hood risers on a 96 ford explorer?? the risers being a piston looking devise which keeps the hood up so you can look at the engine
That or they are clipped on. Have a helper hold the hood for you while you remove the old supports.
Can also clamp one side with a vice grip and it will hold the hood while you do the other side. However, the safest bet is to do it with a helper.
Previous Thread
Next Thread
