Water Pump replacement
Old 04-06-02, 01:20 PM
bernardl
Question Water Pump replacement
I own a 1997 Chev Cavalier and want to change the water pump on a 2.2 litre engine, but I can't seem to find a way to losen the belt. As well are there things I should know before proceeding, such as, will draining the anti-freeze cause a problem?
Old 04-06-02, 01:54 PM
marturo's Avatar
Water Pump
You know after doing 8 to 10 hours a day in the shop , for 3 decades, I could probably look that engine over and do the job.
However I learned something many years ago. Get a work shop manual. For me, they save me costly mistakes, & the customer gets a break, on the time it takes me to do the job.
Best of luck on your job ahead
Marturo
Old 04-06-02, 02:10 PM
Billdo49er
As marturo says it is definitely an easy fix for a tech. As for the do it yourselfer try the link below for step by step procedures.
