3.0 V6 in a 90 dodge spirit taping
Old 04-06-02, 12:23 PM
Negoshe8n
I had the tappets replaced and it is still tapping. The motor has 110,000 on it. It runs very strong. I was told they have to break in first. Is that some crap or what? Is it the rockers that have to be replaced? Thanks
Old 04-06-02, 01:14 PM
Billdo49er
By tappets do you mean lifters?
If they are hydraulic they should of been oiled before assembly.
With proper adjustment they should not tap until after they are broken in.Then they may require a re-adjustment.
Old 04-07-02, 08:54 PM
cheese's Avatar
I'm wondering how you had tappets replaced in a vehicle that has none. It has overhead cams. Sounds like you're getting ripped off.
Old 04-08-02, 09:33 AM
rickwhoo
ohc engines do have tappets
Old 04-08-02, 11:16 AM
spooge031
the 3.0 liter mitsubisi engine used in A LOT of chrysler products definitly has lifters(tappets and they are NOT adjustable) it sounds like you have very low oil pressure or no oil in the engine, the early versions (pre 1993) had problems with valve guides falling down (requires a valve job to properly fix) or maybe the mechanic who did the work installed the rocker shafts backwards (they are directional) I would suggest that you take the car to a GOOD chrysler dealer just to get their oponion and if the work wasn't done right get your money back from whomever did the original work
spooge031 a.s.e.master tech and 15 year chrysler/jeep/dodge tech
Old 04-08-02, 06:09 PM
cheese's Avatar
Ok, I was thinking of lifters/pushrod type setup. There are "tappets" that are recessed into the rocker arms. And they aren't adjustable, but they do rely on oiling from a small hole in the rocker shaft. If this shaft was installed incorrectly, the oiling passages won't be lined up right. That will cause the tapping, and low oil pressure will cause this too, as mentioned. Sorry I was slow to catch up to speed here.
Cough, cough...pulling foot out of mouth!
I am forgetting too many things about cars, guess I've been away from the industry too long. Carry on, and ignore my senility.
