honda accord ABS pump leak
Old 04-06-02, 06:05 PM
smokef16
My '92 Honda Accord EX (manual transmission) ABS pump is leaking from a small hole above the bleed valve (the hole looks like it's supposed to be there). I was told this indicates a bad pump similar to a weep hole on a water pump leaking before it fails. The resevoir is full @ the pump, and @ the master cylinder. I just bled all four brakes at the calipers. Does this sound familiar, or did bleeding the brakes cause problems? I didn't go near the ABS. Also, I don't get any other indications of failure (only fluid in the engine compartment). I could see it coming out this hole when my wife applied the brakes. Help.......
Old 04-06-02, 07:13 PM
Billdo49er
I don't know too much about Honda ABS systems,But the link below may be helpful.
Old 04-06-02, 07:55 PM
Joe_F
Exclamation
ABS and guesswork do not belong in the same sentence.
If the link Bill provided comes up empty, time for an Alldata.com subscription or the Honda service manual before going any further.
