Head gasket or cracked head?
Old 04-07-02, 03:21 PM
GregH's Avatar
Super Moderator
My tale of woe: ('89 Chev van with carburated 350.)
About 15 minutes into a one hour highway trip my 350 started pinging quite loudly. This engine has about 60,000 Km on a jobber rebuild, was running well and I inspected the timing chain just a short while ago.
Upon checking the engine I found several loose intake manifold bolts. I tightened them, the engine ran fine and I finished my trip. Since then I have been getting cylinder pressure in my cooling system.
I can see signs of overheating on my exh manifold and would be interested in what could be damaged.
I have just removed both heads and on a quick inspection cannot see any obvious defects in the gaskets or the heads.
I have yet to do a thorough clean-up and inspection, but am wondering what the most common fault would be.
Unless I see a problem I plan to replace head gaskets and see what happens.
Any thoughts?
By the way, I found some bolts on the intake manifold that look a little short . This may be the reason for the intake leak.
Old 04-07-02, 05:08 PM
Greg,
I don't know what these guys would do, but if I can't see a gasket problem, I would go ahead and check the heads for flat and cracks (magnafluxed) while its down. It's a real pain but you're already there with the heads off. No sense in pulling them twice!
Old 04-07-02, 05:16 PM
Joe_F
I agree with Bill. You can't tell anything by looking at a head. It takes a machinist with specialized equipment to know how to do it right in most cases.
They will also check for burned valves and other woes in the engine.
We had a guy that worked with us that had an engine rebuilt by a engine rebuilder. Turns out later on when he had cooling system issues, we had to redo the motor. They left the 1981 original valves in there and they were burned!
