car repair
Old 04-08-02, 12:16 PM
J. A. Meridieth
car repair
I have a 1991 Chevy Astro and the door handle on the back door is broken how do I fix it?
Old 04-08-02, 12:21 PM
Billdo49er
Try the link below it may be very helpful.
It'll be under body and trim.
Old 04-08-02, 01:25 PM
xiii13
You can access it thru the panel on the inside of the passenger rear door. I've got a '90 GMC Safari and have taken the rear door apart numerous times to fix things. The panel is just below the window and is large. About sixteen phillips bolts to remove it. It might be behind carpeting or fabric depending on your application. The fabric or carpeting have to be removed first using a screwdriver and prying the plastic holders out.
