86 accura integra waterpump replacement
Old 04-08-02, 03:36 PM
raonease
Question 86 accura integra waterpump replacement
I am looking for information on replacing the waterpump on an 86 accura integra. I'm pretty good under the hood just haven't dived into this repair before.
Thanks,
W
Old 04-08-02, 04:42 PM
Billdo49er
Try www.autolibrary.org it has step by step procedures for a variety of repairs.
Old 04-08-02, 09:59 PM
knuckles
The most difficult part of this job is removing the harmonic balancer bolt. Honda torques the bejesus out of these things & many 1/2" drive impact wrenches won't remove them.
If you don't have access to air tools, you can buy a special crankshaft holding tool to hold the crank while you use a BIG breaker bar to remove the bolt.
Replace the timing belt while you're in there...you have to remove it to get the water pump off anyway.
