speaker replacement
speaker replacement
How do I remove the interior door panels, in order to replace the door speakers in a 1992 Honda Prelude SI? Any and all suggestions will be helpful. Thanks.
Sincerely,
Jesse Nickens
Sincerely,
Jesse Nickens
Remove any visible screws, and check for any hidden ones. Remove the arm rest and the door handle cover. If the windows are manual, you will need to remove the window crank, which is held with a spring tension clip. If it has power windows, you may need to remove and disconnect the window switches, or it may be easier to leave the switches on until the panel is completely removed.Same with electric door locks. The door panel itself is held with plastic clips on the bottom and sides, which can be removed by prying out carefully. Then lift the panel up and off.
Note that some models may vary slightly. Refer to a service manual if you need more detailed instructions.
