95 plymouth neon window
Old 04-09-02, 08:10 AM
sean11
Question 95 plymouth neon window
95 plymouth neon, need help to fix back door window, it will not roll down, manual window
Old 04-09-02, 09:00 AM
Joe_F
Manual or automatic?
Start by looking at the links in my signature file below.
Old 04-09-02, 02:18 PM
Billdo49er
Is it manual or electric?
Old 04-09-02, 05:49 PM
merlo
I think this vehicle has a cable window regulator system, which could be the problem, the cable may be twisted and tangled. If thats the case, the regulator will need to be replaced. However, another possibility is that there is a problem with the alignment of the window. You will probably need to remove the door panel to find out exactly what is preventing the window from rolling down.
