left front wheel rolls side to side
Old 04-09-02, 12:19 PM
ramo
It is a 1990 Toyota Corolla with automatic transmission. Eight or Nine months after I have replaced both half shafts, the right front wheel start rolling side to side, it is kind like a Zig-Zag. Then I put new four tires did balance and wheel alignment twice and it did not fix it. I switch the wheels from front to back, replaced ball joint, struts and still didnot fix it. What else is there? Am I overlooking something? I really appreciate your input.
Old 04-09-02, 12:24 PM
Joe_F
You might have a bad hub/wheel bearing assembly.
Do you hear any howling when you drive?
Old 04-09-02, 07:23 PM
ramo
Joe
someone mentioned it could be bad wheel bearing, but I don't hear anything when I drive.
Thanks.
Old 04-09-02, 08:11 PM
Joe_F
Have it checked out. Could be a cracked unibody or bad tie rods. Tough to say without seeing/inspecting the car.
Either way, it's not good if the wheels don't turn true
