coil assembly
Old 04-09-02, 02:04 PM
boman's Avatar
coil assembly
Anyone know where I can get a coil assembly for a '93 Mazda 626 6 cylinder? The thing comes off the distributor and I can't see why I can't buy just the coil assembly somewhere without having to buy a complete distributor..
The distributor has the numbers- KL01 3422 A TOT57071 B
J885 3330 and Mitsubishi on it. Any info would be appreciated.
Tx
Old 04-09-02, 02:27 PM
Billdo49er
Like most Japanese cars if anything goes in or on a distributor.You have to replace the whole thing.
Have you tried the dealer.Sometimes you can just buy the part you need.Not often though.
Old 04-09-02, 02:32 PM
boman's Avatar
Don't think I have, but I will; although, it will prop cost as much as a new distributor somewhere else.
Tx for the response, won't hurt to check with them
Old 04-09-02, 03:42 PM
Joe_F
Make sure it is your problem. I see NA (not available) in all the aftermarket parts catalogs I'm looking at.
Old 04-09-02, 05:08 PM
boman's Avatar
I checked with an ohm mete per a Haynes ( I think ) book I have and it shows to be bad. I have also called around to some of the parts houses to see if they could check it. No luck there. I'm pretty sure that it is the coil assembly. No luck here at finding it seperate either. I guess they got us on some of these parts.
Old 04-09-02, 08:25 PM
Joe_F
Try www.weekendmechanicsclub.com
That is an online parts catalog that Profit Pro powers. It's not too bad. I have used it as reference at work.
